10 years agoImplementing an asynchronous counter in a FPGA
I need to implement a 32-bit counter that counts random impulsions in a FPGA. The counter has to be asynchronous (or not?) for the following reasons: - low consumption - to latch the impuls...
10 years ago --- Quote Start --- Anyway in your last post you talked of superposed pulses: in this case the method doesn't apply, since you'll miss the pulse edges whenever they merge --- Quote End --- I just wanted to give the width of the pulse that needs to be captured. The merge will be handled differently. That was not related to the discussion, that why I didn't give more details. I am going to try it out, and I will give you feedbacks Thank you Damien
