10 years agoImplementing a table
Hello all, I'm trying to implement a table with stored switching angles for an inverter on to an FPGA. I'm a beginner so I'm having a lot of trouble figuring this out so please bare with me. H...
10 years ago --- Quote Start --- You could do it with 7 in parrallel or if you know the data rate is much less than your clock you can just pipeline it (ie. 1 request produces 9 clocks of results). Its up to you how you design it. But verifying with a 7 seg will be a bit of a chore. First of all verify the design in simulation with a testbench, then attach some communication core (like an RS232 port) so you can communicate with a PC. --- Quote End --- So I think I have finally figured out how to make the block. Any advice or tutorials on how to verify it in the testbench? Do I use ModelSim or something else, and if so which file do i open with ModelSim?
