15 years ago
implement Memory using Logic
I'm working in a design using the CIII. I'm usin ROM to store ,mif files. My design took two much memory but a few logic and the quartus can't fit the design in my device. I just wondering if i can map those memory using logic.
Please help me.
    If you are using the megafunction to instantiate the ROM you have a parameterization option to force the logic to be implemented in LEs. Before doing so I would take a look at your implementation to make sure there are not other optimizations you can do first since if your ROM is big, implemented in LEs it'll be slow.
    logic will not store anywherer near as much as ram. you need to get a larger part or re-design your system
    To store data there are three options:
    memory blocks
    registers (of the fabric)
    wires (for constants)
    see if you can use the last two options.
