10 years agoimage read in vhdl
i want to read an image (or preferably a matrix of size 8x8) pixel by pixel in one clock cycle(if rising edge then read one pixel in 2nd rising edge 2nd pixel)....thanks in advance
10 years agoFor a start, this is never going to work. It looks like you're trying to write sofware. This is clearly not the full code as there are lots of things missing (like a process, architecture, etity etc).
So errors in your code: row_pixel is an array of length 1. Your for loop also never executes as you have 0 downto 3 (a null range). I suggest you go back to the drawing board - literally. DRAW your intended circuit on paper before you write any VHDL. VHDL is a hardware description language. Not a programming language. Writing code like software will not work.
