17 years agoIm not Sure if its the right place to post
I got Cyclone II FPGA starter Kit. I want to create an entity that will handle the seven segment in it in all my projects. something I can just add and it will automatically be assigned to the correc...
17 years agoPlease consider, that location assignments have to be done to pins of the top level entity. An 7-Segment module or entity hasn't anything to do with top-level pins. If you accept to use identical pin names in all designs, you can simply copy the assignment tcl lines from an example design's *.qsf file and import them to your new design.
