17 years agoIm not Sure if its the right place to post
I got Cyclone II FPGA starter Kit. I want to create an entity that will handle the seven segment in it in all my projects. something I can just add and it will automatically be assigned to the correc...
17 years agoI am afaid you can't go that automated. You need to manually assign the pins. The kit itself is never visible to HDL.
Create your 7 segment entity, decide its functionality if you haven't got one ready-made then assign pins as appropriate. You can connect switches to the input of your module so that it can be used all over your project for whatever purpose. edit: some compilers accept pin attributes in code level
