17 years agoIEEE 1394b (Firewire)
Hi, I'm trying to figure out the best way to add a Firewire interface to my device that uses a Cyclone III FPGA. Basically I get a lot of data from a bunch of sensors and want to ship it to a ...
17 years agoUnfortunately, it won't be easy. I haven't found any readily available IP for a 1394b link-layer controller for Altera FPGA's.
You could get the PCI core and a 1394b OHCI chip from TI, but that also seems like overkill. Unfortunately, if you want to do 1394b it seems that you might be best off doing your own link-layer controller and getting a PHY chip from TI. Another option might be to go the GigE route and use the Tri-Mode ethernet MAC from OpenCores. Good luck!
