i219LM and i211AT LAN adapter
- 6 years ago
Hi Alexntk,
We are just following up.
It looks like you need more time to assess the answers that we have provided.
We will follow up again after 3 business days. Should we not hear from you, our system may automatically close the thread.
Alfred S
Intel Customer Support
Hello Alexntk,
Thank you for your kind patience.
Please see below update from our engineering level.
It is not possible for a connection to stay active when it is physically disconnected, that's how Ethernet works. If this is not what you meant by your query, please let us know and we will further investigate.
Have you considered using static IP address? This will ensure that when you reconnect you always have the same IP address. However, when you disconnect the Ethernet you don't have an IP address.
Can you check if setting up a Loopback address is an option/applicable for you? We believe this can install a Microsoft Loopback Adapter that emulates an Ethernet card which you can assign a dummy IP address. You can also consider contacting Microsoft to verify this with them.
https://docs.microsoft.com/en-us/previous-versions/tn-archive/cc708322(v=ws.10)?redirectedfrom=MSDN
Let us know if you have additional questions and clarifications.
Looking forward to your reply.
Should there be no response, I’ll make sure to reach out after 3 business days.
Crisselle C.
Intel® Customer Support
- AlexNTK6 years ago
I was able to test two network cards with Realtek controllers inside. If you set the static IP address, the controller retains the IP address even if the cable is pulled out from the network card. Why doesn't this happen with your network adapters? What has been changed or removed to prevent the same behavior with Intel devices?
Thanks a lot.
Alexx
