JJin01
7 years agoI want to use external switching clock.. plz help
My design need a external switching clock, which is an input clock that can externally reset its clock rate. I need to constrain this clock, but I don't know how to do it.. ryan scovil' time...
- 7 years ago
Are you saying that the input clock can be anything between 10 MHz and 300 MHz? If so, you'd probably want to constrain for the fastest clock (replace ext_clk with the name of your top-level clock port:
create_clock -name ext_clk -period 3.3 [get_ports ext_clk]
Then, if it's going through a PLL, just use:
derive_pll_clocks
#iwork4intel
sstrell
7 years agoAre you saying that the input clock can be anything between 10 MHz and 300 MHz? If so, you'd probably want to constrain for the fastest clock (replace ext_clk with the name of your top-level clock port:
derive_pll_clocks
#iwork4intel
- JJin017 years ago
I understand, thank you!
