14 years agoI have problem... top level design entity problem
i defined project name test0 and made the file name and entity name and2. The code is working good . I set the and2 file top-level entity. but i have top level entity problem ..error : top...
14 years ago --- Quote Start --- should the project name , entity name and file name be all the same? --- Quote End --- it's not compulsory that they must be the same, but having same entity name and file name will make things easier for you when you set top level entity from the file window. if not, you got to open settings-> assignment and set the top entity name.
