CChan217
7 years agoI have a problem using the JTAG to program stratix 10 1SG 085 HN3 F43 E1VG. I have the follow error -> Error (18950) : Device has stopped receiving configuration data Error (18948) : Error message received from device: Device is in configura
My circuit design no need to use the any Transceiver and 3V I/O pinany Transceiver and 3V I/O pin. so all the power pin of Transceiver tie to GND that mention on the Stratix 10 device Family Pin conn...
Rahul_S_Intel1
7 years agoHi ,
The above will be a known problem, can you please try the procedure provided in the below KDB.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2018/jtag-configuration-failure-due-to-improper-pmbus-slave-mode-sett.html?wapkw=error+%2818950%29
