16 years agoI got a problem on DE2-TV,I2C_controller
I2C_SCLK begins at SD_COUNTER 4 and ends at SD_COUNTER 30,while I2C_SDAT begins at SD_COUNTER 3 and ends at SD_COUNTER 29.Why don's they transfer data in the same time.
IN addation ,I2C_SDAT also don't write into I2C_SDAT。 The following is partly the program wire I2C_SCLK=SCLK | ( ((SD_COUNTER >= 4) & (SD_COUNTER <=30))? ~CLOCK :0 ); wire I2C_SDAT=SDO?1'bz:0 ; always @(negedge RESET or posedge CLOCK ) begin if (!RESET) SD_COUNTER=6'b111111; else begin if (GO==0) SD_COUNTER=0; else if (SD_COUNTER < 6'b111111) SD_COUNTER=SD_COUNTER+1; end end //---- always @(negedge RESET or posedge CLOCK ) begin if (!RESET) begin SCLK=1;SDO=1; ACK1=0;ACK2=0;ACK3=0; END=1; end else case (SD_COUNTER) 6'd0 : begin ACK1=0 ;ACK2=0 ;ACK3=0 ; END=0; SDO=1; SCLK=1;end //start 6'd1 : begin SD=I2C_DATA;SDO=0;end 6'd2 : SCLK=0; //SLAVE ADDR 6'd3 : SDO=SD[23]; 6'd4 : SDO=SD[22]; 6'd5 : SDO=SD[21]; 6'd6 : SDO=SD[20]; 6'd7 : SDO=SD[19]; 6'd8 : SDO=SD[18]; 6'd9 : SDO=SD[17]; 6'd10 : SDO=SD[16]; 6'd11 : SDO=1'b1;//ACK //SUB ADDR 6'd12 : begin SDO=SD[15]; ACK1=I2C_SDAT; end 6'd13 : SDO=SD[14]; 6'd14 : SDO=SD[13]; 6'd15 : SDO=SD[12]; 6'd16 : SDO=SD[11]; 6'd17 : SDO=SD[10]; 6'd18 : SDO=SD[9]; 6'd19 : SDO=SD[8]; 6'd20 : SDO=1'b1;//ACK //DATA 6'd21 : begin SDO=SD[7]; ACK2=I2C_SDAT; end 6'd22 : SDO=SD[6]; 6'd23 : SDO=SD[5]; 6'd24 : SDO=SD[4]; 6'd25 : SDO=SD[3]; 6'd26 : SDO=SD[2]; 6'd27 : SDO=SD[1]; 6'd28 : SDO=SD[0]; 6'd29 : SDO=1'b1;//ACK //stop 6'd30 : begin SDO=1'b0; SCLK=1'b0; ACK3=I2C_SDAT; end 6'd31 : SCLK=1'b1; 6'd32 : begin SDO=1'b1; END=1; end endcase end Hope for the answer ,thanks4 Replies
Thank you ,I will have a try.
I didnt get it myself but you can change it so it either gives '0' or the data bit to be sent. It works either way.
--- Quote Start --- the first couple of counts sets up the start condition for the write process and the last couple of counts are the end condition. I2C_DAT is the program data coming into this module and I2C_SDAT is the serial data going to the codec. Hope this helps --- Quote End --- Thanks for your help.According to your explanation I understand it. And I hope you can help me to solve another problem: wire I2C_SDAT=SDO?1'bz:0 ; It is the above problem too.It looks like that, the data does not transferred to the slave chip.When the data is "0",the controller writes 0 to I2C_SDAT,but when it is "1",the controller writes "z" to I2C_SDAT ,so writing is shut up. It is about I2C_BUS. Thank you very much! - Altera_Forum
