16 years agoI failed to realize double times frequency by using code!
I want to use code to realize double frequency by using code, However I failed. ------------------------------------------ the following is the code. LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.AL...
16 years agoYou can never rely on logic cells to move signals by any fixed amount. I can see you are trying to move it 50% out of phase so you get a 2x clock. You cannot do this in an FPGA.
For a start, the synthesisor is going to remove all of the inverters because temp4 = clk. then once all the inverters are removed, clk_out is the same as clk in. The synthesisor minimises boolean logic equations as the first step. not ( not ( not (not clk)))) = clk. Phase lock loops are used to do what you want. Look into these in the manual of the FPGA that you are using.
