zlan01
6 years agoI design a board with max10,and do not design the reset input for max10, how can I generate a internal reset ?
Can I use the locked output of pll to generate a reset signal for my design? And what is the best reset mode for max10 ?using a input reset or generating a reset signal just in FPGA ? For my board,t...
zlan01
6 years agoto intel engineer
the sys_clk is 200Mhz, and the initial value of the counter register is 30'd200_000_005 need about 1 second to count,
I want to know :
1) which implementation is better , ak6dn's(directly using the input clcok ) or mine ?
2)if using ak6dn's, and the pll has several output clocks, the asynchronously asserting and synchronously desserting must be done according to different clock domain,right ?
3) what is the intel oppion about that whether a input reset pin should be used or not ?
