8 years agoI can't modify a file in quartus after generated the QSYS system? Please Help.
I'm making a flash controller in FPGA. I wrote the principal controller code, and another file that works like a test bench (a counter that generates the write and read instructions with datas) I nam...
8 years ago --- Quote Start --- QSYS makes a copy of all the hdl files when you generate the hdl, so you are right that each time you modify your HDL files you need to regenerate the QSYS system before compiling the project again. Or you edit the copies, but you risk getting them overwritten the next time you click generate. There is no "back-up" of the project for signal tap, as long as you make sure that the QSYS system has been regenerated, this is what will be in the FPGA and what you will see in signaltap. What you can see is the waves from the previous run, if you saved a signaltap file with data. But as soon as you click "run analysis", it will be overwritten with new data. After you compiled the project you can use the RTL viewer to check that your code modifications have been implemented by Quartus. (and generally the RTL viewer is great when you need to check that Quartus understood what you meant in your code). --- Quote End --- Thanks Daixiwen, I did as you said, after made changes in Quartus, I regenerated in QSYS. Consequently changes are made in the submodule of the .qip project. However the Signal Tap II keeps showing me the old values I inserted previously, this is, the previous version of the verilog file. I don't get why. It is possible that the problem is in the TCL addressing a old version of the file? or that I have to set the Signal Tap to refresh the screen with the new values of the file??
