I can program .sof by programmer, but I can’t program .pof by programmer. Why? What would cause this problem?
I have two pieces of board. One is OK while the other is what I mentioned in the case. I don’t know why I can’t program .pof which could be programmed several days ago.
All are the same including the same programmer for two FPGA board. One can be programmed with .pof by Jtag while the other can’t. Is there problem with hardware of Jtag? I suspect while Both of them can be programmed with .sof by Jtag. Or may be caused by configuration about programming with Jtag?
Info (209060): Started Programmer operation at Mon Dec 02 14:06:09 2019
Info (209017): Device 1 contains JTAG ID code 0x031820DD
Info (209016): Configuring device index 1
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Dec 02 14:06:12 2019
Error (209012): Operation failed
- Vicky1
HI,
I would like to request the members in Intel community please always provide specific details about tool(Quartus) edition & version, device part number & if possible screenshot in thread details for narrow down the issue.
If you are using Max 10 devices in you custom board, please go through the below solutions & let me know if you have any different issue with above details.
https://forums.intel.com/s/question/0D50P00003yyTB4SAM/max10-pof-programming-fail
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2018/why-does-programming-a-max-10-device-in-multiple-device-jtag-cha.html
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd06162015_613.html
Vicky
- Vicky1
Have you resolved the issue?
May I know any update?
Vicky
- Vicky1
Have you gone through my previous post?
"I can program .sof by programmer, but I can’t program .pof by programmer. Why? What would cause this problem?" ----- Are you able to program *.pof?
Vicky
- Vicky1
May I know any update or Should I consider that case to be closed?
Vicky
- ak6dn
Without you telling us specifically about the board you have (development board, custom design, ...?) and what devices are on the board (FPGA, config eeprom) you will not get much help.
As a general rule, if you ask questions here you need to provide as much background info as you can (as Vicky says) or else no one can help you.
- KWang97
The board is custom design with MAX10: 10M08SAU324I7G and Quartus Prime Standard 18.1. Thanks!
