I can program .sof by programmer, but I can’t program .pof by programmer. Why? What would cause this problem?
Hi,@Vicky
Only checkbox "Enable real time ISP ..." is selected can .pof be programmed while if still can't program .pof when not select it. I just don't why there is such a problem while .pof can be programmed without selecting this several days ago.
Have you gone through my previous post?
"I can program .sof by programmer, but I can’t program .pof by programmer. Why? What would cause this problem?" ----- Are you able to program *.pof?
Vicky
- KWang976 years ago
Sometimes .pof can be programmed while sometimes can't even I try the methods in the three issues you provided. I don't know why. You could close this case for now. Thanks for your help!
- Vicky16 years ago
Have you resolved the issue?
May I know any update or Should I consider that case to be closed?
Vicky
