8 years agoI am not getting expected response in Modelsim
Dear all,
Could someone please have a look at my code and say what is wrong in it. entity pinconfig is port( pins :in std_logic_vector (13 downto 0):="00000000000000"; signalsin :inout std_logic_vector (35 downto 0); signalsout :inout std_logic_vector (35 downto 0) ); end pinconfig; architecture behav of pinconfig is component iobuffer PORT ( datain : IN STD_LOGIC_VECTOR (35 DOWNTO 0); oe : IN STD_LOGIC_VECTOR (35 DOWNTO 0); dataio : INOUT STD_LOGIC_VECTOR (35 DOWNTO 0); dataout : OUT STD_LOGIC_VECTOR (35 DOWNTO 0) ); end component; type c is array (0 to 35, 0 to 2) of integer range 0 to 35; signal config : c := ((0,0,1),(1,1,1),(2,2,1),(3,3,0),(4,4,3),(5,5,0),(6,6,3),(7,7,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), (12,12,3),(13,13,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,18,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), (24,24,3),(25,25,3),(26,26,3),(27,27,0),(28,28,3),(29,29,0),(30,30,0),(31,31,0),(32,32,0),(33,33,0),(34,34,0),(35,35,3)); --signal config : c := --((0,27,3),(1,29,3),(2,31,3),(3,5,0),(4,4,3),(5,4,0),(6,13,3),(7,18,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), --(12,12,3),(13,6,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,7,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), --(24,24,3),(25,25,3),(26,26,3),(27,0,0),(28,28,3),(29,1,0),(30,33,0),(31,2,0),(32,34,0),(33,3,0),(34,35,0),(35,32,3)); --config(x,x,0) = out (fpga => gpio) --config(x,x,1) = in (fpga <= gpio) --config(x,x,2) = constant low (pin) --config(x,x,3) = high-Z (pin) signal temp: std_logic_vector (35 downto 0); I Used 2 different pin configurations. Both failed thanks11 Replies
Hai Raj,
I am not writing test bench . I directly compile through Quartus RTL Simulation.
