HSIO Differential Clock Output VOD and VOCM
- 2 months ago
For the FPGA receiver, the key parameters are VID and VICM.
From the schematic, the 10 kΩ/30 kΩ divider biases both inputs to approximately 0.75 × VIO_BANK0 (≈0.9 V for a 1.2 V bank), which falls within the documented True Differential Signaling receiver common-mode range. Therefore, the bias network itself appears compatible with the Agilex 5 HSIO receiver requirements. The remaining check is that the incoming differential clock meets the specified VID range and uses the recommended differential termination.
Altera Tech Support
Thanks for you reply.
I understand that the transmitter will work on only TDS 1.3V.
But now I am asking for the receiver. HSIO bank voltage is 1.2V and using the bank for clock input accordingly please review the bias circuit.
Jay
Altera Tech Support
