11 years agoHPS power consumption
If I use only FPGA part of Cyclone V SE device, the HPS is in reset state with CPU0 and CPU1 or I should load code to sleep CPU1? And if HPS is not used the default frequency is 800 MHz? Should I ...
10 years ago --- Quote Start --- If I use only FPGA part of Cyclone V SE device, the HPS is in reset state with CPU0 and CPU1 or I should load code to sleep CPU1? And if HPS is not used the default frequency is 800 MHz? Should I load code to slow down CPU to save energy? Thanks --- Quote End --- maybe you can consider to use Cyclone V instead? as HPS is not your game here.
