11 years agoHPS power consumption
If I use only FPGA part of Cyclone V SE device, the HPS is in reset state with CPU0 and CPU1 or I should load code to sleep CPU1? And if HPS is not used the default frequency is 800 MHz? Should I ...
10 years agoThanks for clarifying, now I begin to understand, then we have the same use-case as flz47655. Indeed we want to use only the FPGA part to save power (in our case: to avoid heat).
Our FPGA engineers (I'm from software), however, told me that a CycloneV can't be started up without the pre-loader - which is HPS software off course. Is this true ? Or can everything, that is normally done by the pre-loader, also be done in a different way ? This would be really awesome because it would make things much easier for us. Thanks a lot.
