11 years agoHPS power consumption
If I use only FPGA part of Cyclone V SE device, the HPS is in reset state with CPU0 and CPU1 or I should load code to sleep CPU1? And if HPS is not used the default frequency is 800 MHz? Should I ...
10 years agoI see, the original post was for a dual core CycV :) We have only a single core CycV and fusing its reset line would ultimatively disable the preloader :) And yes, this IS crazy :D But we have economical reasons to re-use a certain COM that we obtain in high volumes, and that one has a CycV HPS we just don't need.
I put a while(1) { __asm__("WFE"); } into the HPSs kernel code now, as a first step.
