10 years agoHPS power consumption for Arria V SOC using PowerPlay Tool
Hello, I am new to SOC design. We are using an Arria V SOC chip. I used the Quartus PowerPlay tool to estimate the various supply currents required. I turned the USE HPS option on in the HPS cal...
10 years ago --- Quote Start --- Hello, I am new to SOC design. We are using an Arria V SOC chip. I used the Quartus PowerPlay tool to estimate the various supply currents required. I turned the USE HPS option on in the HPS calculator screen and set the CPU freq to 800MHz. After running PowerPlay I see a VCC_HPS (1.1V core) current of only 30mA. This seems extremely low to me. I was expecting to see something > 1A at least. Am I doing something wrong or making some bad assumption? Thanks, - Matt Knapp --- Quote End --- I have to assume that you're missing some peripherals as being on, or core usage. I haven't looked at the Arria V setup, but I know the Cyclone V was like that.
