15 years agohow tooutput a high speed clock
I need a clock to control high speed AD.But I measure it with oscillograph finding it is very bad so that AD can't work. thank you very much
15 years agoRelated to the jitter performance of high speed ADC, the FPGA clock tree is not so good, but I guess, it can keep with your 1 MHz ADC respectively the involved S/H circuit.
Does the output clock become good if I use the PLL of FPGA? ======================= Another option is to derive the sample event from an analog interpolated DDS signal, as e.g. provided by the Analog Devices DDS chips. DDS chips output sinusoid.How can I use it to derive ADC?(add a compator?) ========================= But I didn't yet hear about the aperture jitter of your ADC which is the basic hardware limitation for the system. --- Quote End --- I don't understand the jitter of ADC. I think the if the clock isn't beyond the maximum frenquency,the ADC can work properly.
