15 years agohow tooutput a high speed clock
I need a clock to control high speed AD.But I measure it with oscillograph finding it is very bad so that AD can't work. thank you very much
15 years agoI think you are talking about random sampling, so it need the trigger. But I use the sequence sampling(I think random sampling is harder than sequence sampling). I just need one trigger (or a reset ) to start the sampling, while needn't trigger at every sample point.
First,I get the count value of one period of signal(count at main clock).Then, I sampling one point per N+1 cycles. I don't know that it is good method or not . I am very confused at the signal processing of FPGA(include the input signal and output signal,as I said before the output signal wave is bad and FPAG need low jitter input signal). Do you have any idea to deal with the problem.
