16 years agohow to write code to realize n times frequency?
Hi,all! I want to know how to write code to realize n times frequency? There is no PLL/DLL in some CPLDs, So in this sitution I need to write a short hdl code by myself to realize the same funct...
16 years ago --- Quote Start --- In order to multiply the frequency you need a fast oscillator (this can be done) a phase detector (this also can be done, perhaps) and a method to modify the oscillator frequency (very difficult in FPGA). Even if it works the performance should be very poor. What about using an external PLL/DLL component? --- Quote End --- Thanks for your reply! Yes,you're right. It's OK to use an external PLL/DLL, but It maybe a little complex if we don't have an external PLL/DLL and can't use the CPLD/FPGA's existing resources. Now I only want to know how to use code to realize it. and I believe It's workable.
