17 years agoHow to view a configured FPGA contents?
Hi, I have a board with Cyclone II and its config. Flash mem. What I want to do now is to verify if the contents of the config data stream (original is a POF file) is the same to the POF file I...
17 years agoHello
You could go to Quartus Programmer, select your .POF and check the "Verify" box only. Click on Start and it will compare your file with the one from the Flash Regards Thiago
