14 years agoHow to use two USB blaster cable in the same computer
We want to debug different FPGAs/cplds which are in different JTAG chain at the same time using same computer. And we have several usb blaster cables, but one computer only recognizes one usb cable. ...
14 years ago --- Quote Start --- Yes, you are right. Unfortunately, my supplier makes all USB blasters with a same ID:(. --- Quote End --- That doesn't matter. You can use FT_PROG to read the USB-Blaster EEPROM, save it to a template, and then re-write the EEPROMs with new serial numbers. You can even write your name in there if you want, eg., JERRY00, JERRY01, etc. Here's the FTDI application: http://www.ftdichip.com/support/utilities.htm#ft_prog Cheers, Dave
