14 years agoHow to use two USB blaster cable in the same computer
We want to debug different FPGAs/cplds which are in different JTAG chain at the same time using same computer. And we have several usb blaster cables, but one computer only recognizes one usb cable. ...
14 years agoHi, I think 2 usb Blaster can be plugged in the same PC. There are distinguished somewhere (In Nios II command line, I could select which USB Blaster I want to use but i didn't try)
but because of usb, you are NOT sure that Windows points to the same USB Blaster. It may be difficult to check and assign USB Blaster to the good board. Other guys talked about multiple USB Blasters in the Altera forum. Good luck !
