16 years agoHow to use Memory ALUTs
I'm new to Quartus II, and I'm having trouble fitting my design to a Stratix III board. When I looked into the logic utilization of my design, i noticed that the Memory ALUT utilization was 0. Is there some way i can use memory the Memory ALUT for me to fit my design? I'd really appreciate any reply, especially from the gurus. Thanks!1 Reply
--- Quote Start --- Hi, I'm new to Quartus II, and I'm having trouble fitting my design to a Stratix III board. When I looked into the logic utilization of my design, i noticed that the Memory ALUT utilization was 0. Is there some way i can use memory the Memory ALUT for me to fit my design? I'd really appreciate any reply, especially from the gurus. Thanks! --- Quote End --- Hi, Memory ALUT's are ALUT's which could be used for memory implementation. These ALUT's could be also used to implement logic. A memory ALUT utilization of 0 does not mean that the ALUT's are not used. It only means that they are not used as memory. Can you explain your problem a little bit more ? What is your resource bottleneck ? Registers, Memory ... Kind regards GPK
