14 years ago
How to use functions in packages on testbench code.
Hi all,
How to use functions in the packages to testbench to give inputs a and b code.
function to_max(a, b : integer) return integer is
variable output :integer;
begin
if (a > b)then
output := a;
return output ;
else
output := b;
return output;
end if;
Thanks in advance
Raghavendra
    --- Quote Start ---
    Thanks..How can i use in testbench code.
    --- Quote End ---
    1. Start by reading the two replies that you got to your question when you first posted it.
    2. If you're still confused, then ask a question about where you are confused by those two replies
    3. Don't ask the same question twice, when it was answered the first time.
    KJ
    eg:
    package my_function is
    begin
    if (a > b)then
    output := a;
    return output ;
    else
    output := b;
    return output;
    end if;
    end package my_functions
    library ieee
    library work
    use work.my_functions.all
    entity test_program is
    port (
    x,y : in integer;
    y : out integer
    architecture beh of test_program is
    begin
    y =to_max(x,y) ;
    end architecture beh;
    not synthesizable code but this is just a guide. hope it helps
    include it as all other packages. e.g.: use work.my_functions.all
