10 years agoHow to use FPGA delay one signal edge in 1 ns while keep other edge unchange?
Hi, Recently I am thinking is it possible to use a FPGA device do such kind of thing: Use FPGA generate USART mater transmit signals, a 30Mhz clock, each clock cycle generate a bit data. ...
10 years agoThis is sometimes done by making the wire for the clock slightly longer than the wire for the data. This could also be applied to traces on a PCB. Using the constraint Tricky mentioned above works by adding cells for the purpose of delaying the signal.
