Joakim's avatar
Joakim
6 years ago
How to use D5_DELAY or D5_OE_DELAY on Cyclone V
I'm desperately trying to get the timing to work between my Cyclone V and an external CPU. Because of the clock delay, it seem to be impossible to get the timing to pass within one clock cycle, so I tried to get it to within 2 clock cycles using multi cycle.
But in that case my data is delayed 22 ns instead of 3 ns. Looking at Chip planner, I notice that the tool has set D5_OE_DELAY to 31, which should be maximum delay.
So how do I get it to use a more reasonable delay, like 10 ns?
I have tried:
set_instance_assignment -name D5_DELAY 8 -to FX3_DQ[0]
or
set_instance_assignment -name D5_OE_DELAY 5 -to FX3_DQ[0]
But it seem to be ignored (the 8 and 5 are at the moment just experimental numbers).
  • Jodok's avatar
    Jodok
    Hi Joakim,
    I encountered a similar behaviour. Did you found a solution to your problem?
    Greetings
    Tom
