How to test a SPI module.
hello, i trying to test an spi module that i add in a system that im using, i used this code but i dont know why there is an error:
/* * principal.c * * Created on: 11/04/2012 * Author: RONALD */ # include <stdio.h># include "system.h" # define ALT_MODULE_CLASS_SPI_1 altera_avalon_spi# define SPI_1_NAME "/dev/SPI_1" int main() { FILE *fp; printf("Hello from Nios II!\n"); // fp = fopen("/dev/SPI_1","r+"); //opens module spi if(fp==0)//if doesnt exist the module do this printf("\nError Opening %s\n\n",SPI_1_BASE); else//do this if the module exists { printf( ""spi comunication success \n"); } return 0; } when i run this code for to test the spi module the program shows me ""Error Opening", could you help me with these please3 Replies
AFAIK altera_avalon_spi can only be a master and can't be configured as a slave.
Did you read the document I suggested you? It describes the alt_avalon_spi_command() function that you can call to send SPI commands. - Altera_Forum
Hello Daixiwen, thanks for your help, but my SPI module is configurated as slave, how can i test my SPI module if it is a slave??, Could you send me some example code?? thanks in advance, sorry if i am not clear, im an ecuadorian student, i speak spanish but i know some english :-), im doing a SPI analyzer, it is my graduation proyect, and until know i have my machine in qsys, now i want to test my modules created, i´m going to need a uart module, and with a code similar to the code that i told you in the post, i tested it and it worked, but with my spi slave dont :-(, im new in altera forums, help me wwith this pease. thanks again
You can't use the file API to use a SPI master, it uses its own API. Have a look at this document (http://www.altera.com/literature/ug/ug_embedded_ip.pdf), pages 8-8 and over, for more details about the SPI controller API.
