17 years agohow to store program into UP3 permanently?
Do someone can tell me that why i download my program to UP3, after switch off the current, the program is not stored! after switch on, then i need to download it again! does it my source codes...
17 years agoAs a first point, the POF file is generated automatically by Quartus, when AS configuration is selected. You may also want to enable bitstream compression to reduce the image size.
--- Quote Start --- in AS programming, i even cant to download into up3 at both jp11 & jp12. can not detect any device chain. and it even can not change any device also at AS mode. --- Quote End --- Sorry, this sounds confused. It's very clear in the UP3 reference manual, that JP11 is intended for AS programming. Also, as said there's no device chain in AS programming, just a single device accessed by Quartus programmer. The Quartus Programmer has a mode: Combo Box on top of tool window, it has to be set to active serial programming instead of jtag. To my opinion, Quartus Programmer operation is really intuitive, but you'll find verbose software handbooks, if you want.
