17 years agohow to store program into UP3 permanently?
Do someone can tell me that why i download my program to UP3, after switch off the current, the program is not stored! after switch on, then i need to download it again! does it my source codes...
17 years ago --- Quote Start --- cant add target EPCS4 to device chain while in current programing mode --- Quote End --- You apparently tried to access EPCS4 in JTAG programming mode. That can't work, you must set the Quartus Programmer to AS programming. P.S.: I also wondered, if the UP3 reference manual possibly misses an explanation of the different configuration methods and their particular purpose. I think, it basically has it at page 13 of the Version 01 manual.
