17 years agohow to store program into UP3 permanently?
Do someone can tell me that why i download my program to UP3, after switch off the current, the program is not stored! after switch on, then i need to download it again! does it my source codes...
17 years agoi found
--- Quote Start --- JP11 is used when you are happy with your design, and have told the tools to convert the .sof file to a .pof file via a check box selection) and wish to have it perminently stored on the board in the EPCS1 PROM. --- Quote End --- at this thread http://www.alteraforum.com/forum/showthread.php?t=4826 i just dont so understand about how to check the box selection! i cant find it, if i directly add .pof to download, it will show the "cant add target EPCS4 to device chain while in current programing mode" and i did connect my jtag cable to jp11 port, if i add .sof to download, will fail too! can someone give me a hand?! i really urgent to present for my final year project!
