15 years ago
How to store file from RS232 to SDRAM/FLASH/SRAM ?
Hi everyone, do you know how to store file from RS232 to SDRAM/SRAM/Flash?
Thank you very much.
    The lrvrl converter may be the following:
    http://focus.ti.com/lit/ds/symlink/trsf3221e.pdf
    for UART.... you should write it or get something like this:
    http://soursecodes.blogspot.com/
    You need only the RX part and the modules which serve it...
    For writing into SRAM look at the DPR specification. It is usually like this:
    CLK: ____________|--------------
    _________
    xxxxxxxxxx WR DATA xxxxxxxxxxx
    _________
    xxxxxxxxxxx WR ADDR xxxxxxxxxxx
    WR_EN ____|-----------|__________
    Thank for your ans... can i have any reference of it? I am a beginner of it.. Thank you very much ..
    This is for SRAM:
    1. the RS232 should pass 1'st the RS232 to LVTTL or LVCMOS by hardware
    2. then, in FPGA you may instantiate UART (with the right settings and BOUD rate).
    3. Then, when you get the octets, each octet should be written into SRAM (produce WR pulse) and address counter. should be incremented to next sample location.
