15 years agoHow to store file from RS232 to SDRAM/FLASH/SRAM ?
Hi everyone, do you know how to store file from RS232 to SDRAM/SRAM/Flash? Thank you very much.
15 years agoThe lrvrl converter may be the following:
http://focus.ti.com/lit/ds/symlink/trsf3221e.pdf for UART.... you should write it or get something like this: http://soursecodes.blogspot.com/ You need only the RX part and the modules which serve it... For writing into SRAM look at the DPR specification. It is usually like this: CLK: ____________|-------------- _________ xxxxxxxxxx WR DATA xxxxxxxxxxx ------------- _________ xxxxxxxxxxx WR ADDR xxxxxxxxxxx ------------- WR_EN ____|-----------|__________
