18 years ago
How to Simulate ROM Megafunction in Altera-Modelsim
Could any one help me out on how to simulate ROM Megafunction,
Actually I tried both by generating .hex as well .mif format , but I couldnot get the results.
It is a single port ROM ,
With clock , address and q as signals,.
When I simulate I see the outputs (q) to be zero every where. Is there any procedure to follow to read the actual values ??/
Hope any one respond and help me out ..
Srinath.
    Hi.
    I like to read and write data to SSRAM on the board .
    Could you please help me what are the timings that I should maintain for that ?
    Is there any document explaining how to do ??
    I am using Nios II Evaluation Board (Cyclone III EP3C25F324N6) ,
    I am stuck , s please provide me the information
    Thanks ,
    Srinath.
    Thanks for the reply...
    My results are up ....
    Thanks a lot for the immediate reply..
    A possible reason is that your initialisation isn't read. If so, it could be seen from a simulation warning. Generally *.hex is required for ModelSim, and must reside in ModelSim project directory, that's where the modelsim.ini and *.hdp project files are located. The ROM content can be examined also in simulation memory window.
