17 years agoHow to set analog delay MaxPlusII
Hi, I need to set a delay following a rising_edge of a sig_a. In order to do that, I have utilized the: c<=sig_a; x <= c after# nS; -- where I can select the# through a data on the bus. ...
17 years agoIf you add your delay with buffers it may vary with temperature.
If you explain more about why you need to delay something for such a short time as 1 ns it will be easier to assist you. Is there anyway you can get around using a delay? Can you delay it with a register for 1/fmax s? What fmax do you have in your system? Best Regards, Ola Bångdahl
