16 years agoHow to save the output of module running in the fpga?
Hi all, I'm using cyclone2 ep2c35 fpga development board and there are flash, SDRAM memory chip in it. I want to save the output of the module in pc for further analysis. How should i do to ac...
16 years agoDo you have serial port on you development board? If so you can direct your output through serial port to the PC. First collect your output in a FIFO and then send it through RS232 interface as fast as you can.
