17 years agoHow to reduce LAB usage in MAX II devices?
I'm currently using MAX II - EPM1270T144 device while the fitter says it requires 128 LABs to implement the project, but the device contains only 127 LABs. But i noticed the LE(logic element) usage h...
17 years agoYou should look in the MAX II Users Guide.
http://www.altera.com/literature/hb/max2/max2_mii51002.pdf Look at LAB control signals for some clarity. In some cases it is one, in other cases it iw two. ASYNC signals are a challenge. Try to get things into a SYNC mode, and control stuff with CE controls if possible.
