11 years agoHow to properly add time constraints for a 32-bit Parallel Port Write
Hi all, I am using a Max II CPLD EPM1276J144C5N interfacing through the parallel port of a AD9914. I am relatively new to constraining my designs and I would like to pose this question. h...
11 years agoJan,
Firstly, WR seems to be an active LOW signal. The 'bar' over the signal name indicates that - although the datasheet only seems to explicitly clarify that for CS. Your suggested sequence, perhaps, suggests you're expecting WR to be active high. I'm suggesting the following: 1st clock cycle: WR is deasserted (high), data/address presented 2nd clock cycle: WR is asserted (low), data/address hold 3rd clock cycle: WR is deasserted (high), data/address hold A little further reading reveals the address is latched on the falling edge of WR and data is latched in on the rising edge. The above sequence should still work. Cheers, Alex
