8 years agoHow to program EPCQ with .jic file on Altera C5EFP board?
I use C5EFP board, https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-e.html I program the EPCQ with jic file, get Error (209025): Can't recognize silicon ID...
8 years agoHi,
--- Quote Start --- Remove resistor R16 and R22, populate resistor R18 and R23? Set MSEL to 10011? --- Quote End --- Yes, that's correct. --- Quote Start --- Connect a USB blaster cable? --- Quote End --- Should be connected to the jtag header j4 while programming .jic file. Refer below link for more information. http://www.alterawiki.com/wiki/configuration_walk-through https://www.altera.com/support/training/course/odev1100.html https://www.altera.com/support/training/course/ocnfgsch.html https://www.altera.com/support/training/course/ocnfgsol.html Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- BXia7 years ago
Hi Anand Raj Shankar ,
"Should be connected to the jtag header j4 while programming .jic file"---Coudl you help confirm if it must connect J4 via USB Blaster cable to program .jic file? Why can't connect J10 via USB cable to program .jic file?
