8 years agoHow to program EPCQ with .jic file on Altera C5EFP board?
I use C5EFP board, https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-e.html I program the EPCQ with jic file, get Error (209025): Can't recognize silicon ID...
8 years ago --- Quote Start --- Hi,
- Check if the .jic file is generated for correct EPCQ device(Check it on board).
- Have you connected the USB blasters to the J6 connector(AS/PS) header?
- Try with MSEL std mode 10011.
- Is FPP configuration successful?
