8 years agohow to program adxl345 on DE10-Lite in verilog?
hello all,
as the title, I'm trying to read the device ID of adxl345 on my board in 4-wire SPI, but I have some problems, I get the wrong device ID (every bit is one). The following is my code, and I don't kwon where I make mistakes. Can anyone tell where I make mistakes and how to get the correct device ID?module sensor(sw0,clk,hex0,sdo,sdi,cs,sclk);
input sw0,clk;
output hex0;
input sdo;
output cs,sdi,sclk;
reg cs,next_cs;
reg sclk_ctrl,next_sclk;
reg sdi,next_sdi;
reg address;
reg data,next_data;
reg cnt,next_cnt;
reg state,next_state;
pll p0(
.inclk0(clk),
.c0(clk2)
assign sclk=(sclk_ctrl)?clk2:1'b1;
assign hex0=(cs)?data:8'd255;
always @(negedge clk2) begin
if(sw0) begin
state<=next_state;
cs<=next_cs;
sclk_ctrl<=next_sclk;
cnt<=next_cnt;
sdi<=next_sdi;
data<=next_data;
end
else begin
state<=3'd0;
cs<=1'b1;
sclk_ctrl<=0;
cnt<=4'd15;
address<=8'b11000000;
sdi<=1'b0;
data<=8'd0;
end
end
always @(*) begin
case (state)
3'd0: begin //pull cs to 0
next_state=(sw0)?3'd2:3'd0;
next_cs=1'b0;
next_sclk=1'b0;
next_cnt=4'd15;
next_sdi=1'b0;
next_data=data;
end
3'd2: begin //make sclk be a 1MHz clock and input register adrdess through sdi
next_state=(cnt==8)?3'd3:3'd2;
next_cs=1'b0;
next_sclk=1'b1;
next_cnt=cnt-8'd1;
next_sdi=address;
next_data=data;
end
3'd3: begin //receive the output of sdo
next_state=(cnt==0)?3'd4:3'd3;
next_cs=1'b0;
next_sclk=1'b1;
next_cnt=cnt-8'd1;
next_sdi=1'bx;
next_data={data,sdo};
end
3'd4: begin //data transmission is completed,pull cs and sclk to 1
next_state= 3'd5;
next_cs=1'b0;
next_sclk=1'b0;
next_cnt=cnt;
next_data=data;
end
3'd5: begin
next_state=(sw0)?3'd5:3'd0;
next_cs=1'b0;
next_sclk=1'b0;
next_cnt=cnt;
next_data=data;
end
default: begin
next_state=(sw0)?3'd1:3'd0;
next_cs=1'b1;
next_sclk=1'b0;
next_cnt=4'd15;
next_sdi=1'b0;
next_data=8'd0;
end
endcase
end
endmodule
and this is the result(using signal tap) https://www.edaboard.com/attachment.php?attachmentid=145116&d=1520248193&thumb=1 (https://www.edaboard.com/attachment.php?attachmentid=145116&d=1520248302) thanksNo RepliesBe the first to reply
