17 years agoHow to preserve nets during quartus analysis/synthesis
Hi, I new to using Quartus- I'm using v 5.1. After doing analysis/synthesis, while setting up Quartus simulation, I notice that the user-entered node names appear to be synthesized away. I...
17 years ago --- Quote Start --- Hi, I new to using Quartus- I'm using v 5.1. After doing analysis/synthesis, while setting up Quartus simulation, I notice that the user-entered node names appear to be synthesized away. In other words, to display the sim results of a node, I must choose the origin of that node. If I choose an unregistered node as a destination, it disappears from the simulation waveform window. Any suggestions would be appreciated, Gary --- Quote End --- Hi Gary, you can use one of three synthesis attribute in order to preserve node: in verilog: to save a wire: wire net1 /* synthesis keep */ ; to save reg: reg reg1 /* synthesis preserve */; if the register has no fanout you have to use reg reg1 /synthesis noprune */; Kind regards GPK
