13 years agohow to measure timing in QII?
Dear all,
I want to measure timing of a project. Is it built in like Timing Constrain or delay? or I can put a timer? Is it possible on QII to know the time of specific element or block not the whole project? Thanks in advance1 Reply
Hi ,
What do you mean by timings of a project ? compile time ? or timing in simulation ? Yes Quartus has Timing constraint file where you define the timing constraint of specific signals or signals of interset. This file is used by the compiler and then by fitter to monitor which signals are failing set-up time or hold time . Regards ,
