12 years agoHow to measure distance between two data
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them. d(s1,s2)=(1+1+0+1+1)...
12 years agohi kaz
i need your help ,plz if you remember the design you made before that measure the distance between two samples d(s1,s2). if i have 4 samples such as [ s1,s2,s3,s4 ] and i want to get the distances between every two samples, then i would have d(s1,s2),d(s1,s3),d(s1,s4),d(s2,s3),d(s2,s4)and d(s3,s4). what should i do 1 or 2 1- should i repeat the module of test 6 times and i would have 6 component of that module connecting together to get the 6 distances between every sample and the other ...or 2- should i use the module of test one time and store the distance in register and reset the module then measure the distance between the next two samples and store the the result in another register again and so on.... what can i do ?? so really i need your advice thanks a lot and i hope you answer this time!!!
